1999 Z28 Camaro signal relay.
Old 04-06-2010, 03:11 PM
brohemo's Avatar
When i turn the turn signal on, the dash indicator light lights up but its a solid light, no flashing. The exterior lights have the same problem they light but do not flash. I removed the flasher relay from under the right side of the steering column. Is this what needs to be replaced or could it be something else? Thanks everyone.
brohemo is offline
Old 04-06-2010, 03:40 PM
Adam96Z's Avatar
Sometimes a burnt out bulb, bad ground, or bad socket will cause the same problem. Flasher relays are cheap so might be worth a try though. You can get one at any auto parts store.
Adam96Z is offline
Old 04-06-2010, 09:53 PM
A burned out bulb or filament is the most common cause. Check bulbs.
shoebox is offline
NewsBot
12-28-2014 06:20 PM
Not Dave
12-11-2014 06:32 PM
pete53
12-09-2014 07:31 AM
Brandon Wittmer
12-03-2014 09:28 PM
07-04-2005 05:00 PM
Quick Reply: 1999 Z28 Camaro signal relay.
