1999 Z28 Camaro signal relay.
When i turn the turn signal on, the dash indicator light lights up but its a solid light, no flashing. The exterior lights have the same problem they light but do not flash. I removed the flasher relay from under the right side of the steering column. Is this what needs to be replaced or could it be something else? Thanks everyone.
Sometimes a burnt out bulb, bad ground, or bad socket will cause the same problem. Flasher relays are cheap so might be worth a try though. You can get one at any auto parts store.
A burned out bulb or filament is the most common cause. Check bulbs.
