1996 ss overheating
Old 09-20-2014, 09:50 AM
Bob9196's Avatar
1996 ss overheating
I have a 1996 SS convertible that the fans will not kick on. They do come on low when you turn the A/C on. They come on high when you unplug the temp sensor. but they wont operate when the engine comes to temp with the sensor pluged in. I have replaced the waterpump, temp sensor and Relays. could there be something wrong in the PCM
Bob9196 is offline
Old 09-20-2014, 11:59 AM
Re: 1996 ss overheating
How hot does it get? What temp is "comes to temp"?
The stock programming is low speed fans at 226*F, high speed fans at 235*F.
Injuneer is offline
Old 09-22-2014, 11:06 AM
Bob9196's Avatar
It overheats it passes 240 gauge maxed out fans don't come on
Bob9196 is offline
Old 09-22-2014, 11:21 AM
Check the coolant temp sensor wiring for the one in the water pump housing. Check the accuracy of the sensor in the driver side head for the gauge:
4th Gen LT1 F-body Tech Articles
If you have access to a scanner, see what reading the PCM is getting, compared to the gauge reading.
Injuneer is offline
Old 09-28-2014, 03:43 PM
REDNECKISBOSS's Avatar
One more thing to add. There is a plastic shield that is about 8 inches behind your front bumper. Its a air dam, ment to force air through your radiator at a certain speed.be sure you have this or you will overheat at higher speeds
REDNECKISBOSS is offline
AviatorDave
12-19-2016 06:35 PM
Quickss96
01-29-2016 05:56 PM
truecontr3
10-11-2015 09:30 AM
damnyankee36
09-09-2015 07:06 PM
Pwilson59
09-03-2015 08:47 PM
Quick Reply: 1996 ss overheating
