1994 z28 lt1 swap to 1998-2002 v6 camaro
OK so my 1994Z 28 Camaro I was about to get it painted and get a rocker panel fixed when I found out it had been wrecked previously. It had pushed the inner fender well in and crunched it in and I was quoted of having to have it put on a frame stretcher to pull that out. I also found front in damage and a rear quarter panel under the carpet that was damaged as well. So I’m looking for a new body and found a 1999 V-6 Camaro automatic with T tops how hard would it be to swap my stuff into that car and would it be possible? Engine trans etc?
Re: 1994 z28 lt1 swap to 1998-2002 v6 camaro
Lot of work. K-member, PCM, wiring harness from the 94. Major mismatches with the body harness. Problems interfacing with the 99 body control module electronics, digital data input to the instrument panel. OBD-2 issues. Issues with the fuel tank OBD-2 features pressure sensors, canister vent. 99 V6 doesn’t even have an accelerator cable, since that was the first year the V6 had the electronically controlled throttle body.
