Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
What is the cause of the this sparking? help
Old Nov 24, 2009 | 09:15 PM
  #16
dalynchmob's Avatar
Well i guess that would be the last thing to do? Would the ignition module, next to the coil, have anything to do with this type of problem?
Old Nov 24, 2009 | 09:28 PM
  #17
rclearyiii's Avatar
I do not believe there is any high voltage within the ignition module that could cause the arching that you have described.
Old Nov 24, 2009 | 11:49 PM
  #18
dalynchmob's Avatar
ugh i hope thats it then. I mean the opti either works or doesn't right?
Old Nov 25, 2009 | 06:26 AM
  #19
rclearyiii's Avatar
The opti can still work and give problems just like any other distributor.
Old Nov 25, 2009 | 07:38 AM
  #20
dalynchmob's Avatar
Well if i'm gonna be in there and with the problem i have it seems to make sense to change the whole thing if the cap rotor aren't noticably the problem.
Old Nov 25, 2009 | 08:12 AM
  #21
colbear96Z's Avatar
Yea your gonna Need an e4 reverse tourqes bit to get the cap off.
Old Nov 25, 2009 | 10:33 AM
  #22
dalynchmob's Avatar
Good call on the reverse bits i don't have those. Thanks.
Old Nov 25, 2009 | 11:17 AM
  #23
rclearyiii's Avatar
you will also need a t9 torx bit to get the rotor off if you decide to replace just the cap and rotor.
Old Nov 29, 2009 | 11:53 PM
  #24
dalynchmob's Avatar
I'm pretty mechanically inclined but is there anything tricky about changing an opti? I mean if the car is running and the opti is intact can i mess it up? I'll be checking shoebox's website to see if there is a step by step but figured i'd ask since i was on here.
Also the optical sensor, what is the correct term for that? Is that the ignition module that sme come with and some don't?
I know the MSD one comes with everything, anyone have anything good or bad to say about the msd's?
Old Nov 30, 2009 | 09:34 PM
  #25
dalynchmob's Avatar
Ok got it off and inspected. The rotor and cap looked normal. When i looked at the back of the opti i noticed some significant cracks in the metal casing and the edge of the casing around the cracks looks discolored. If i could figure out how to post pics or someone could help me i would love to share them to see what you guys think. I haven't got the correct size tiny socket to get the case apart but i will tomorrow. i want to see if the cracks are all the way through. (pretty sure it's my prob)
BTW good call on the E4 socket colbear
Thought i had the t9 but alas i only had a t10 rclearyiii
Who sells a dependable complete setup at a reasonble price with fast shipping? (like by friday)
Old Dec 3, 2009 | 06:57 PM
  #26
dalynchmob's Avatar
Ok got a new opti put on and bought a new ICM also. I'm happy to report that after replacing the coil, wires, ICM, opti harness, and opti no more clicking/cracking sound. I also replaced the O2 sensors. She fired right up ran well on the road but still has a low end hesiation i think it might be time for some new injectors. Mine only have 173k on them What do the resident experts think? When i step on it she goes then you can feel the power increase after a second or so like something is catching up. Wierd but drivable right now until i hear from you guys on what you think.
Old Dec 4, 2009 | 08:51 PM
  #27
SoloExceptional's Avatar
I had a low end hesitation on a car once like it was trying to catch up to itself. Mine ended up being a cracked spark plug porcelain was very hard to spot.
Old Dec 17, 2009 | 08:20 PM
  #28
dalynchmob's Avatar
Solo you were very close on the cracked porcelain. Found my # 5 wire dried and it snapped of in my hand when i went to change the drivers side wires. Runs like it's got 8 cylinders now haha. Thanks to all.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
