Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Vacuum line hook up
Old Apr 17, 2010 | 07:21 PM
Amotek's Avatar
Vacuum line hook up
Need to know if there is an easy way to hook the vacuum line for the HVAC back up to the block! Dealer quote to repair is over $600.00. With the line disconnected I can't control the HVAC output and it defaults to defogger.
Old Apr 17, 2010 | 09:55 PM
For starters, you need to tell us what year/model/engine your car is.
If its a 4th Gen, the check valve usually falls apart, and needs to be replaced. Shoebox has info that applies to most 4th Gens:
http://shbox.com/1/hvac_vacuum.jpg
http://shbox.com/1/vac_check_valve.jpg
LT1 specific:
http://shbox.com/1/evap_sol.jpg
Old Apr 17, 2010 | 10:27 PM
Amotek's Avatar
Yeah, I've checked that out before. The vacuum line hook up is on the very back of the intake manifold. I did the checks and determined there was no vacuum present at the canister. I was hoping someone might know of a way to reconnect the vacuum line without having to remove the intake!
Old Apr 18, 2010 | 04:15 AM
MikeGyver's Avatar
Assuming your car is an LT1, its the top vacuum port on the passenger side in the middle of the intake manifold. There are no ports on the back of the manifold.
Old Apr 18, 2010 | 08:42 AM
Amotek's Avatar
I wish it was, but it is a 2000 SS, local dealer took a look at it and it ws determined that the location was there.
Old Apr 18, 2010 | 09:51 AM
You really need to add a "signature". Even after I asked what car it was for, you ignored the request. Its so simple to just add the d@mn signature, showing year, model, engine, trans and major mods. That way people can HELP you, without making a lot of wild @ss guesses. I could have told you where the connection was on a 2000 LS1, but there was no way to know that's what you owned.
Where the vacuum connection is located makes very little difference... you just need to find a friend who can reach back there and hook up a new vacuum line. No way that is a $600 repair. But have it your way.
Old Apr 18, 2010 | 10:48 AM
Amotek's Avatar
The vehicle is a 2000 Camaro SS LS1 6SPD. It would take an anorexic long armed double jointed friend to reach the connection and reattach the vacuum line, I have no such friend. I have tried several times to create a sig line, to no avail. The $600.00 was a quote from the local Chevy dealer and in no way is it my way. That is why I came here seeking some help. Thanks for your courtesy and commiseration!
Nellsw88
May 26, 2015 05:55 AM
May 8, 2015 11:30 AM
lt1matt
Mar 21, 2015 07:35 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
