Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Is there a write up for changing out the fuel pump?
Old Jul 26, 2009 | 07:51 PM
Skyhawk's Avatar
Question Is there a write up for changing out the fuel pump?
Ive searched but cant find ****. I know you either have to drop the rear end or cut a hole in the back to change it out, and I would like to cut the whole to get to it.
Where can I find a write up for this? Will it be any different in my car since its a convertible?
Old Jul 26, 2009 | 09:59 PM
IXLR894Z28's Avatar
I thought I saw an article on this at www.installuniversity.com a while ago, you can check there.
Old Jul 27, 2009 | 01:42 PM
2001NBMZ28's Avatar
I know two people who had the trap door method done for bad sending units. One was on a '98 and one on a '00 - tanks are different so use a guide for a '98 when cutting. LS2.com has a '98 writeup, but not a vert - don't think it would be different.
Old Jul 27, 2009 | 01:55 PM
2001NBMZ28's Avatar
Found the link I was thinking of, maybe it'll help. I'd make absoultely sure it's the pump before using either method. http://www.ls2.com/forums/showthread...hreadid=460724 Good luck.
Old Jul 31, 2009 | 07:22 AM
AL SS590 M6's Avatar
Moderator
This isn't an engine tech question. I'm going to move it to an appropriate forum.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
