Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel injector
Old Sep 24, 2011 | 11:37 PM
undecidedfbody's Avatar
Fuel injector
I had just put together my motor and was wondering what size injector I can use
383 stroker
Callies crank
Je pistons
Crower rods
237/242- 595/598 110 lsa
Advanced induction 200 cc heads with geometry corrected intake
1.6 pro mags
I was goin to go with a set of 42lbs
Like to have some insite please thanks
Old Sep 25, 2011 | 10:15 AM
Re: Fuel injector
42 #/HR injectors will support up to 600HP normally aspirated. You would appear to be within that limit.
Old Sep 25, 2011 | 12:55 PM
Re: Fuel injector
Thank you cause I see some guys running 30lbs in some h/c/I cars so now I know I need 42's
thank you
Old Sep 25, 2011 | 03:37 PM
Re: Fuel injector
To get the minimum recommended size for an NA engine, multiply the flywheel HP by 0.07
That assumes an 0.476 BSFC and 85% DC.
Example: 500 HP x 0.07 = 35#/HR
Old Sep 25, 2011 | 04:11 PM
Re: Fuel injector
So I am thinking I'll have 425 to the wheels so I think 30lb would be good 425x.007 =29.75
Old Sep 25, 2011 | 04:14 PM
Feenix's Avatar
Re: Fuel injector
duty cycle on injectors go by the power at the crank before drivetrain loss. Going by 15% loss you'd want to go by 500 fwhp if you expect 425 at the wheels. In which case i'd go with the 42's.
Old Sep 25, 2011 | 04:47 PM
Re: Fuel injector
I see now thank you for the input
Old Sep 25, 2011 | 10:36 PM
Re: Fuel injector
I posted above that you need to multiply the FLYWHEEL HP. The injectors have to make the power at the flywheel. They have no way of knowing whether you are loosing 13% through a T56 or 25% through a loose TH400.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
