Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Stuck ignition lock cylinder
Old Jun 5, 2014 | 08:39 PM
LazyLemming's Avatar
Today I started the car and it started normally. But when I released the key it stopped about halfway between the run and start positions.
I was able to get the car home, but I had to shut off the vehicle by pulling the ignition fuse and then disconnecting the battery. I cannot get the ignition to turn back from where it's at.
I can turn it forward and start the car, if I let go it goes back far enough the starter kicks off but all the accessories are still shut off. No amount of wiggling will turn the key farther than this.
I know how to change the lock cylinder but that's parts and money I'd prefer to avoid. I'm hoping there's an off chance one of you knows some sneaky way to fix this...
Old Jun 5, 2014 | 09:12 PM
Re: Stuck ignition lock cylinder
Could be a problem with the switch, connected to the key cylinder with a rod. Shoebox has a writeup on ignition switch problems.
Old Jun 6, 2014 | 09:43 PM
If you release the rod from the ignition switch and the key turns freely, then your switch is jammed up (likely fried), which is the more common thing.
Rod Bender
Nov 7, 2023 02:30 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
tds1213
Nov 27, 2014 12:55 PM
