Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Stays running while holding key
Old Sep 7, 2010 | 09:15 AM
mudrats's Avatar
My 94 Camaro V6 will not stay running. If I turn the key to start, and let go of the key like normal, the engine will fire for about one second, then die. BUT, if I continue to hold the key at a certain position after the car fires up, the car will stay running and I can drive it around the block, as long as I continue to hold the key on.
I have replaced, the ignition cylinder and key, with matching resistance from GM. Replaced the fuel pump.
Any ideas????
Old Sep 7, 2010 | 10:52 AM
Have you replaced the actual ignition switch (located on the lower part of the column) or tried to adjust it?
Old Sep 7, 2010 | 11:21 AM
mudrats's Avatar
Haven't tried that. Are there any instructions out there on how and where to adjust???
Old Sep 7, 2010 | 05:03 PM
There is a replacement guide on my Tech Page. As far as adjustment for an already installed switch, you can make small changes and test it out.
Old Sep 13, 2010 | 07:23 AM
mudrats's Avatar
We replaced the ignition switch and the car fired up on the first try. Your descriptions and illustrations/photos made the job go very smoothly. Thanks so much for your help!!!!
Mudrat
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
F(ast)-body
Feb 26, 2003 09:05 AM
