Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Running rich as heck
Old Aug 25, 2007 | 01:02 AM
mrmint69's Avatar
What could cause the car to dump tons of fuel into it to the point its blows black smoke and you can smell it on your cloths afterwards. Runs like crap and reving it past 2000 rpm is very hard. My friends car.
Old Aug 25, 2007 | 10:30 AM
mdenz3's Avatar
O2 sensors, MAF sensor, TP sensor, leaky injectors... the list goes on.
Can you get any more information on the problem?
Old Aug 25, 2007 | 10:32 AM
dangalla's Avatar
all good ideas but dont forget the coolant temp sensor
Old Aug 28, 2007 | 06:49 PM
96ZCamaro's Avatar
I am dealing with same problem. I'll let you know about my resolution once I get it figured out.
Old Aug 28, 2007 | 11:14 PM
mrmint69's Avatar
Turns out the FMU was completely blocking all fuel to the return line making over 100 PSI! Then i replaced it with a new one and now i get 10 PSI!?!?!? If i crimp the return line i can get any pressure i like by how much pressure i apply with the crimpers. I assume the fpr is the culprite.
Old Aug 29, 2007 | 07:15 AM
dangalla's Avatar
sounds like it, make sure you get a STOCK fpr
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
