Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Which Racetronix set-up?
Old Feb 10, 2007 | 11:09 AM
69gto96z's Avatar
I am getting ready to get a racetronix pump, and was looking on thunderracings site. There is a $250 and $160 and $90 one. I am trying to decide between the $160 and $250 kit. I plan on running a comp 306 cam along with my n20 set-up i currently have. Heres a link to it. I am unsure as to whether I need the extra stuff in the $250 kit or not.
http://www.thunderracing.com/catalog...vid=4&pcid=166
Old Feb 10, 2007 | 12:23 PM
joe-96z1le's Avatar
The $90 is for the harness. $250 pump includes the harness. The advantage of the harness is that it connects to the alternator to ensure the pump has full voltage. The harness also has an option to add a boost-a-pump which you may not need.
Old Feb 10, 2007 | 02:45 PM
2000GTP's Avatar
I would just get the pump, I have not seen enough postive feedback on the harness to justify the additional cost.
Old Feb 13, 2007 | 10:06 PM
Racetronix's Avatar
This all depends on your HP requirements. The harness will provide an apx. 15-20% output gain under WOT. Just enough is not enough. You always require a safety margin.
Old Feb 13, 2007 | 11:30 PM
magicvega's Avatar
question is will just the pump alone come with a plug and play harness to connect it to the stock wiring so its just pop it in the tank and plug in the harness or is the other harness needed? im interested in this because i want to place a order soon and want to make sure i have everything i need for a smooth setup.
Old Feb 13, 2007 | 11:37 PM
Racetronix's Avatar
The pump assembly (FLT1-FPA) comes with new in-tank wiring and is complete and ready to install. The external harness has nothing to do with the installation of the pump assembly.
Old Feb 13, 2007 | 11:39 PM
magicvega's Avatar
thanks for the quick response. I dont need the extra power so i only need the pump then it seems. Just wanted to make sure cause i hate starting a project and needing a simple part and having to wait 1-2 weeks or more for a part to ship and etc. hehe
Old Feb 16, 2007 | 05:16 PM
69gto96z's Avatar
I will be pushin about 500 rwhp.
Old Feb 17, 2007 | 11:27 PM
magicvega's Avatar
order placed hehe...
Old Feb 20, 2007 | 03:00 PM
Loadre's Avatar
What is the the hp rating limit for the racetronix pump w/ harness?
Quickss96
Jan 29, 2016 05:56 PM
form94
Sep 23, 2015 07:30 AM
94DROPTOPZ28
N2O Tech
Jan 27, 2003 11:56 PM
Racetronix
3rd Gen / L98 Engine Tech
Sep 13, 2002 08:29 PM
jim88iroc305
Aug 13, 2002 09:24 PM
