Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
problem
Old Feb 2, 2007 | 09:41 AM
brucetrentcamaro212's Avatar
problem
I HAVE A 96 CAMARO Z28..
i HAVE A PPROBLEM WITH IT AND WAS WANDERING IF SOMEONE CAN HELP.
It started right after I gased up the tank. about 20min later it started missing at 4000 rpm and then got worse. and now it wont hardly run. It will start every morning but once it gets warmed up a little it dies and will not start back up. intill it gets very cold again. I didnt know if this could be from bad gas ( water in the tank) or a fuel problem. please help about to just get rid of the car from all the problem I have had with it.
Old Feb 2, 2007 | 11:58 AM
FuryZ28's Avatar
Could be wrong, but it sounds like the fuel pump is going out? It's fine when cold, but seizes up after it heats up...I'm pretty sure I've heard from others that it's a sure sign of a dying fuel pump...
Old Feb 2, 2007 | 04:07 PM
Thanks, I think so to. I had a new one put in about 2 years ago. It does backfire a bunch when it does run and strong fuel odor outside too. Any body have any more thoughts
Old Feb 2, 2007 | 04:43 PM
You will need a test gauge to rule out fuel pump pressure problems.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
