Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
optispark problem
Old Oct 14, 2014 | 08:39 PM
  #16
USAirman93's Avatar
Re: optispark problem
Nope. The pin is nearly level with the heads of the bolts also. So surely it's short enough.
Old Oct 15, 2014 | 07:31 AM
  #17
By "mushroom" I meant did you expand the pin diameter?
Are you using the same cam sprocket you were using previously with this Opti? You need the sprocket with the large hole, or the pilot shaft on the Opti will not go into it.
Ditto with the cam:
Old Oct 15, 2014 | 09:09 AM
  #18
USAirman93's Avatar
The pin and sprocket are right. It could be the hole in the cam that's the problem.
Old Oct 15, 2014 | 09:29 AM
  #19
USAirman93's Avatar
So I just checked the depth of the hole in the cam it's the right one
Old Oct 15, 2014 | 09:54 AM
  #20
USAirman93's Avatar
Got it on finally. I took the old one and tried knocking it on with a mallot and it worked. So then I put the new one on and a few light taps later it seated. Thank you for your help injuneer
Old Oct 15, 2014 | 09:57 AM
  #21
It's not the depth of the hole in the cam, so much as the diameter of the hole.
And the nose of the cam has the relief (step) that allows the cam retainer to sit flush against the block?
http://shbox.com/ci/ci294.jpg
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
