Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
optispark problem
Old Oct 12, 2014 | 05:55 PM
USAirman93's Avatar
optispark problem
So I just finished a cam swap and went to install the opti and it won't seat all the way against the engine. The dowel is lined up with the correct hole and the dowel pin is stock length. Idk why it won't seat. Please help. Tia
Old Oct 12, 2014 | 08:30 PM
GaryDoug's Avatar
Prominent Member
Re: optispark problem
The pin height is about .65"?
Old Oct 12, 2014 | 08:46 PM
USAirman93's Avatar
Yes
Old Oct 12, 2014 | 09:22 PM
Did you check the alignment against Shoebox's photo?
Old Oct 12, 2014 | 11:09 PM
USAirman93's Avatar
Sure did
Old Oct 13, 2014 | 06:37 AM
Pullngz's Avatar
For a 1993, I thought the dowel length was .375" I didn't think it was longer until the vented opti's?
Mike
Old Oct 13, 2014 | 07:58 AM
GaryDoug's Avatar
Prominent Member
According to his profile, he has a 95 engine.Too bad it isn't in the sig.
Old Oct 13, 2014 | 08:01 AM
He doesn't have a signature, and he speaks about the dowel pin going into the hole in the back of the Opti. That would make his engine a 95-97. But the "93" in his screen name is confusing.
I've suggested several times that he add a "signature", but he has chosen not to add one, making it difficult to help him.
Old Oct 13, 2014 | 09:51 AM
USAirman93's Avatar
It's all in my signature. Don't know why my signature isn't coming up. It is a 95 engine in a 93 body. The dowel pin is .675" and the opti only goes halfway on
Old Oct 13, 2014 | 09:58 AM
USAirman93's Avatar
Apparently when you post on the mobile site it doesn't include the signature.
Old Oct 13, 2014 | 02:54 PM
Use the full site.... my post immediately above was done from an android phone - no problem with the signature.
Are you measuring the length of the dowel pin from the surface of the cam nose, or from the outer surface on the cam sprocket?
Courtesy of Shoebox"
http://shbox.com/ci/ci289.jpg
Old Oct 13, 2014 | 03:12 PM
USAirman93's Avatar
I feel like an idiot. I was measuring from the sprocket. How do I go about getting this pin to the right length without taking the engine apart again? I appreciate the help guys.
Old Oct 13, 2014 | 03:52 PM
From Shoebox's site:
Before you install the cam, it is a good idea to check the dowel pin length. Compare the new length to the old and make any adjustments if needed. If the dowel pin is too long, it can ruin a vented optispark in a short time (non-vented optisparks aren't driven by the dowel pin). Some have said GM specs indicate that the dowel should be .620" long (protrusion from the front face of the cam) for the vented optispark. Others have said it is supposed to be .685". Mine was actually .650" and still was in no danger of bottoming out in the optispark drive (I'm thinking .685" might be the max it could be).
Here you can see the difference in the Comp Cams dowel (right) to the original. The CC pin was .840". That would put pressure on the back of the optispark and destroy it in a short time. If you have any doubts about the length, use some modeling clay (even PlayDoh :-) ) to test fit the opti and check the clearance. Comp Cams advises you to check all clearances.
If you don't want to change the pin, it can be dressed down by a grinder with relative ease.
Old Oct 14, 2014 | 08:00 PM
USAirman93's Avatar
So I grinded it down to the correct size and it still won't go on. Its seating on the bolt heads and cam pin. So I don't see why it won't go on all the way
Old Oct 14, 2014 | 08:04 PM
Did the pin "mushroom" when you ground it down?
