Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Not Starting
Old Sep 7, 2007 | 05:19 PM
383TransAm's Avatar
Not Starting
O.k. so I hd to do some rear end work on my 93 TA.
Drove the car up on ramps and took everything apart and did what I had to do.
Had to go out of state for a few days so it sat in the garage.
A week later I have everything done and now the car wont start
I have pwr to my MSD box 12.41v!
I have pwr to the ICM at the plug 11.81v!
I have NO spark at the coil to the distributor!
I have NO spark at cylinder 1 !
I swaped out my MSD and put my Accel 300 back in, Nothing.
I bought a new MSD coil, nothing!
If I have no spark at the coil is my ICM shot??
If not what could be my problem??
Old Sep 7, 2007 | 05:45 PM
Did you try flashing the codes on the SES light? Might point you in the correct direction.
Old Sep 7, 2007 | 06:45 PM
383TransAm's Avatar
Ya, sorry!
It flashes 12, shows it good to go
But I still have nothing
Old Sep 8, 2007 | 08:23 AM
383TransAm's Avatar
Hey Fred, could the optical sensor in the opti just go poof??
I did a Opti & Sparck check from the Shoebox site and from what I can tell I have .9v coming to the ICM.
Old Sep 8, 2007 | 09:44 AM
Yes, the optical sensor can die in any number of ways.... slowly or instantaneously. But that would set DTC 16 and/or DTC 36. Problems with the IC Module should also set codes. That's why I asked about the codes.
Old Sep 9, 2007 | 05:55 PM
383TransAm's Avatar
Well for some reason my car did flash any codes but the optical sensor was shot.
As many of us, I part of several diferent sites.
Anything from Local Michigan sites to National like this one.
I was given this link by HBHRacing from F-Body.com
http://www.mainstreamtopics.com/foru...p?showtopic=78
By following his write up I was able to trace my problem.
Thanks to Fred for his help also
Old Sep 10, 2007 | 08:15 AM
Harlan post on Jim Hogan's fbody.com site..... not F-Body.com
Those are two different sites.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
