Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
walbro wiring help!
Old Sep 7, 2007 | 11:54 AM
4SFEDZ's Avatar
walbro wiring help!
im doin a duel intank setup and will 12 gauge wire be good enough 2 run the second pump? what size fuse should i run? it will be on a toggle switch is there anything i should look for in switches?
Old Sep 8, 2007 | 07:25 AM
Boosted_Z28's Avatar
12 gauge wire would be adequate to power the pump, but it should go through a relay and should not be powered directly through a switch.
Old Sep 10, 2007 | 09:45 PM
4SFEDZ's Avatar
why not use a switch?
Old Sep 10, 2007 | 11:05 PM
You do use a switch, but you use the switch to control the function of the relay. All high current draw accessories should be controled using a relay. This enables you to use any switch you want and don't have to run heavy gauge wire to the switch.
Old Sep 11, 2007 | 01:17 PM
mzgp5x's Avatar
I run dual walbro 255 lph intank pumps. Each powered with 16ga with a common ground wire. Had to rework the fuel tank seal mount for twin -6an delivery lines, and, electrical conductors + tank level switch. Also, I run a toggle switch which powers a Painless relay to apply 12vdc power to the 2nd pump. B.
HarleyZ28
Oct 5, 2015 06:23 AM
TitoPR221
May 26, 2015 12:20 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
Skull Leader
Aug 10, 2002 11:01 AM
