Need help with a fuel gauge issue...sounds like one for the Injuneer!!
Posted in the wrong section earlier:
Ran into a problem with my T/A. wouldnt start. checked fuel pressure, nothing. Having just bought the car, and knowing the previous owner doesnt know as much as he thinks he does, I pulled the pump. The suction line was almost completely off the pump. reattached and retightened clamps, reinserted pump, car fired right up with 41psi on gauge with key only.
When I pulled the pump, I looked in the tank, and there is fuel is the lower section (wedge shaped section) only. After reinstalling pump, gauge was pegged at past full. I thought I may have jammed the float, so pulled it and reinstalled it (Hatch mod is a god send!!). After reinstalling pump for second time, gauge reads empty.When I turn key on it will go up to half full, then go back to empty. Following the link on shoebox's site, I Ohm'd the connecter and am getting 0 OHMS between the purple and black wires on the harness running to the tank.
Did my sending unit go **** up? Did I reinstall it improperly??
Any other advice?
Any other advice?
Already responded to your other post, and moved it from LT1 Based Engine Tech to this forum. Couple guidelines on posting, as you already figured out:
-post only on the right forum. If you post in the wrong forum, delete the post (click the "EDIT" buttoin)
-do not cross-post the same question on multiple forums
-do not "page" individuals in the topic. That's what a PM is for.
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
T-REX
May 14, 2002 08:47 PM
