Ltcc Code 2 Error????
Well I just got my LTCC in last night and started up fine. When I drove it is when I felt the miss. Let me start off I got a 97 WS6. So I checked the grounds and show good, then when I remove the cover off the box its a solid green light and a two blink red one? I read the manual and it states that its a miss count from high to low res? Emailed Bob to see if he can help me out so I'm waiting on him but I wanted to see if anyone has had that problem here to see if I can fix it. Went to the dealer and scaned it and it would show a missfire on multiple cyl's then shut it off and tried again and it showed a miss on another set of cyl's? It's a ramdom miss.
Thanks for the help guys. LMK if you need more info.
97 T/A m6
LT's true duals, no 02's "not tuned"
LTCC with used ls1 coils Accel opti "new" Accel super stock wires ngk plugs.
air and egr removed.
97 T/A m6
