Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
LT1 with DELTEQ wire recommendation etc
Old Aug 8, 2010 | 09:03 PM
RACEON's Avatar
I was checking my plugs, see picture, and then I ohmed my wires. 2 were quite a but different.
I am going to get new wires, and with the DELTEQ system, what would be a good wire for a waste spark ignition type. Also, should I put some shielding on the wires?
The numbers above the plugs are the OHM readings for there wire
Old Aug 19, 2010 | 01:55 PM
siguy's Avatar
I used the morso cut to fit wires they have low ohm and work great when compared to the stock wires that come with the delteq system
Old Aug 19, 2010 | 09:23 PM
RACEON's Avatar
Thanks, I put some low, very low ohm, Taylor 409 10.4mm. The plugs I put some NGK TR55 at .035 gap. Runs pretty good.
Ari G
Dec 11, 2014 03:21 PM
pete53
Dec 9, 2014 07:31 AM
Rich_z28
Aug 27, 2002 12:20 AM
Burn_Out
Aug 18, 2002 08:49 AM
