Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
LS1 fuel tank in an LT1 car
Old Oct 11, 2004 | 10:08 PM
  #61
IllusionalTA's Avatar
Re: LS1 fuel tank in an LT1 car
the swap is possible u just need a ls1 style filler neck.. and you should be good to go..
Old Oct 11, 2004 | 10:10 PM
  #62
Camaro SS's Avatar
And the thread is revived from the dead.......
Old Oct 11, 2004 | 10:15 PM
  #63
i seen that.. so i figured i'd post
Old Oct 11, 2004 | 10:55 PM
  #64
slimdawson's Avatar
Wouldn't the ls1 style filler neck be on the ls1 tank?
Old Oct 11, 2004 | 11:35 PM
  #65
atljar's Avatar
Very possible. My buddy did it on his TA. Dont know the details though, sorry.
Old Oct 12, 2004 | 06:33 AM
  #66
Their filler neck is a rubber hose.. and if you get the tank it might not be connected to it.. thats the only reason i said somthing..
Old Oct 12, 2004 | 09:32 AM
  #67
WS Sick's Avatar
I'm looing at this and I am gonna try to just add the fuel return line to the LS1s tank pump housing assembly, It looks very doable.
Old Oct 12, 2004 | 12:03 PM
  #68
slimdawson's Avatar
If it is just the fuel return that is the problem, that is simple. Cut a 1" piece of pipe about 1/4" id and weld it to the pump assembly after a hole is drilled. Are the dimensions where the tank straps go the same?
Old Oct 12, 2004 | 01:16 PM
  #69
WS Sick's Avatar
Well the connections are different as well, but easy to work around.
Old Oct 12, 2004 | 01:17 PM
  #70
WS Sick's Avatar
Oh yeah, the part that the straps go around is identical.
Old Oct 12, 2004 | 05:40 PM
  #71
ronin013's Avatar
so are there any downsides to the swap? you need the tank, the filler neck, and i guess the different fuel pump? and fab some connection points.
sounds so tempting...until i look at the bills sitting on my floor
Old Oct 12, 2004 | 07:24 PM
  #72
slimdawson's Avatar
Electrical connections or fuel? Will an LT1 sending unit assy. fit in the LS1 tank?
Old Oct 13, 2004 | 10:32 AM
  #73
WS Sick's Avatar
Both, the elec plug is different and the fuel lines connections are in a different spot and a different type.
Old Oct 13, 2004 | 10:43 AM
  #74
roadtrip120's Avatar
Any pics that you can post?
Old Oct 17, 2006 | 09:52 PM
  #75
Daniel6718's Avatar
revive the dead..who did it and how much work what year ls1 tank did you use?
and can you use a ls1 tank with the lt1 fuel pump assembely, sending unit, everything from the lines outside the tank to the pump drop it into the ls1 tank or is the opening differant?
heres some link i found
http://www.geocities.com/formulapower2/fuelpump.html
i think this is an lt1 style fuel tank...correct?
is this an ls1 style tank it has an extra sensor on top if it
http://www.neofb.com/gallery (second page, 98z in progress)
trying to find a pic of a 99-02
if this si true cut the metal lines use a short rubber hose with clamps on it right on top of the pump...and srop in the lt1 pump assembely(same 6 bolt hole pattern right?
