Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
LS1 fuel tank in an LT1 car
Old Nov 26, 2002 | 07:12 AM
  #31
SAR2K's Avatar
Thumbs up
Originally posted by Camaro SS
SAR2K...When you attempt/do the swap, try to weigh the two different setups so we can verify the weight difference.
Will do buddy. If I have time I may try the swap as soon as this weekend since it's a Holiday.
Steve...
Old Nov 26, 2002 | 08:36 AM
  #32
Deadcarny's Avatar
i have been wondering this ever since i found out the LS1 had a plastic tank. i was just unsure about the weight savings because of thick plastic and larger capacity. however, with the new light shed that it is an 18 pound difference, i am really wondering if it will work! this would be one of the next mods!
Old Nov 26, 2002 | 08:48 AM
  #33
dreamer1q's Avatar
Ok, heres the deal on the tank according to my interchange at work.
93-97 regardless of engine size fit each other, camaro and firebird
98 camaro and firebird only fit 1998!!! nothing else
99-2002 fit regardless of engine with each other firebird and camaro. The dimensions are different, so I would doubt it would fit. Personally I think it is a bit of a headache to make one work to only gain a gallon and a half. But have fun, hope the info helped
Q
Old Nov 26, 2002 | 01:53 PM
  #34
JordonMusser's Avatar
West South Central Moderator / Special Guest
its not the extra gallon, its the weight
Old Nov 26, 2002 | 02:22 PM
  #35
Chris91Z's Avatar
I think one of the differences in the 98' from the 99+ tanks is that the 98's have the FPR in the fuel rail when the 99+ have it on the tank.
Old Nov 26, 2002 | 08:44 PM
  #36
slp223's Avatar
not all ls1 have plastic tanks I think 98 still have metal. Yes you can just plumb the plastic tank. The www.horsepowerstore.com did it on there car.
Old Feb 14, 2003 | 07:34 PM
  #37
95 Z/28 LT1's Avatar
Super Moderator
Question
Did anyone do this yet?
The new tanks have the regulator on the tank?
Don't make me be the first one dammit!
Old Feb 14, 2003 | 10:10 PM
  #38
Camaro SS's Avatar
Go for it.....I've been waiting for someone to try this.....
Old Feb 15, 2003 | 12:48 AM
  #39
Fear The Z's Avatar
Originally posted by superal
The 93-96 cars do have a low gas light (I made my own gauge overlays and I saw it) but mine has never come on. (have ran out of gas a couple times).
93-96 have low gas lights????¿¿¿ Maybe a low oil light
Old Feb 15, 2003 | 11:40 AM
  #40
Super Moderator
I need to know what the difference is with the fuel lines and the regulator/Pumps and if they interchange.
Old Feb 16, 2003 | 10:32 AM
  #41
Super Moderator
Anyone know if the number of lines is the same between the LT1 and LS1 tank?
Old Feb 16, 2003 | 10:45 AM
  #42
bad96firechikin's Avatar
Someone do this already before I have to!!! Also, how much can the tanks be bought for out of a wreck on average???? Sounds like a cool weight-reduction mod once I do the BMR K-member and control arms.
Old Feb 17, 2003 | 07:47 AM
  #43
Super Moderator
TTT
Old Feb 17, 2003 | 11:27 AM
  #44
supermo26's Avatar
I have a 98 tank froma wrecked car and the tanks is metal. Weight felt the same as my 95 when I moved them from point a to point b, (NO Scales). The pump of the 98 had an extra set of wires and the plastic line connectors were different. The charcoal canister is different from the 95 and 98 also. 98 is rectangle box and my 95 is round. The 98 also has a regulator in the tank on the pumo assembly. The plastic bucket and tube assembly was different as well.
I am only speaking from my experiance from striping down a 98 Firebird LS1 and working on my 95. I also called a dealor and they said the part #'s were different between the tanks. James
Old Feb 17, 2003 | 12:14 PM
  #45
Calli's Avatar
so what about the 99 and up tanks?
