Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
LS1 is acting up, I'm thinking fuel?
Old Nov 25, 2009 | 12:55 AM
GhostZ28's Avatar
Originally Posted by Injuneer
There are "bypass" style regulators that control the pressure AFTER the regulator. You end up with a "dead end" fuel rail, and pressure control becomes a bit erratic with very high HP setups. Every F-Body LS1 engine has this type of fuel system. The regulator is in the tank. Many high HP LS1 systems convert to the full recirculation rails, with the pressure regulator after the rails, because it provide a much more uniform pressure in the system.
I read this, searching for an answer to how many feet i will need in order to run -6 lines from the filter to the rails and return on the LT1, and it seemed to account for my weird hesatations my car is giving me. It only seems to happen when i'm lightly accelerating or cruising and I very gradually accelerate like a grandma (hey i drive mine like a grandma). When I step on gradually (not a swift downward foot motion but pressure) while it hesitates like that it will bog down and i might as well not be accelerating. the weird part is when I tromp it if there is bogging, or i pump the pedal a bit up and down, it snaps out of it and I have full power again. (lol then my clutch slips because of the power jolt) I first thought spark plugs and they did look gross, but I just replaced them trying to fix the problem.
Do you think I need to upgrade to a parallel feed then out to a regulator then to tank?
Old Nov 26, 2009 | 10:28 AM
That would seem to be more of a programming issue, contolling throttle "tip in". Problems with the dead-end fuel system, in high HP applications, will show up when there is high fuel demand, not at low RPM/partial throttle conditions.
Old Nov 27, 2009 | 05:17 PM
GhostZ28's Avatar
ah. looks like i'll be going back to ed
Deadbolt24
Jan 19, 2015 01:29 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ChrisFrez
Nov 23, 2014 10:33 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
