Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Lots of Fuel issues Stock 95 LT1
Old Aug 10, 2016 | 10:26 PM
  #16
GaryDoug's Avatar
Prominent Member
Re: Lots of Fuel issues Stock 95 LT1
Originally Posted by Allanggg2
I unfortunately do not have a laptop, and my roommate probably wouldn't be ok with me downloading stuff on his laptop. Looking at the scanner and cable, how is that going to work? Does the 16 pin end of the cable go into the reader, then I adapt using the 2 wires, like shbox.com shows? My camaro doesn't have the obd1 connection.
Here's how it works. The cable supplied will fit your 95, but I don't remember if it will work without some modification. Give me a few days to find out. Also the power supply in the CP9127 is a 12vdc pack that many people have already for other devices and it allows you to scan the pcm. See if you already have one of those for camera or something like it.
Correction: I forgot that without the external supply, the tool will not scan; it just handles files already stored for the pc. So, you either need 12v at the DLC (94 no, 95 yes) or a cigar lighter power adapter like the one supplied with the CP9127 cable kit.
Old Aug 13, 2016 | 09:44 PM
  #17
GaryDoug's Avatar
Prominent Member
I should have something by Monday PM.
Old Aug 15, 2016 | 01:09 PM
  #18
GaryDoug's Avatar
Prominent Member
Just in case anyone is watching.... The CP9185 will work on a 95 without the CP9127 cable kit, because the 12v is already wired to the connector in a 95. I had forgotten about that.
Old Sep 1, 2016 | 11:05 PM
  #19
Allanggg2's Avatar
So, any updates on this? From what I see, you said I don't need any kind of external power output, and I'm ok to get the cp9185 scanner? Am I going to need that cp9127 adapter cable with it too? Huge thanks for looking into it
Old Sep 1, 2016 | 11:53 PM
  #20
Originally Posted by GaryDoug
?..... The CP9185 will work on a 95 without the CP9127 cable kit, because the 12v is already wired to the connector in a 95......
So, any updates on this? From what I see, you said I don't need any kind of external power output, and I'm ok to get the cp9185 scanner? Am I going to need that cp9127 adapter cable with it too? ?......
WhiteZ95
Sep 17, 2016 08:30 PM
bowtieboy95
Jul 1, 2015 06:49 AM
Nickster 7
May 1, 2015 09:04 PM
naaz90
Jul 27, 2002 08:22 AM
Zomie
Jul 22, 2002 03:34 AM
