Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
key switch problem on a 95 z
Old Feb 15, 2010 | 04:58 PM
jakesm89's Avatar
got a problem...when i turn the key to "run" my guages are supposed to come on, fuel pump ect ect...but nothing happens.
but when i turn the key forward to engage the starter everything comes on and the starter cranks and engine runs
however, as soon as i let off on the switch everything shuts off. the car is in the "run" position halfway to "crank". could this be a key switch rod malfunction? my high beams dont click on either
thanks
Old Feb 15, 2010 | 05:05 PM
Read Shoebox's guide, and see if this helps you out:
http://shbox.com/ignsw/ign_switch_repl.html
Old Feb 15, 2010 | 05:09 PM
jakesm89's Avatar
yes ive already searched through it, im pretty sure the actual switch is fine. im thinking i might have to adjust the rod somehow? it starts everytime and runs fine as long as im keeping the switch half turned
Old Feb 15, 2010 | 06:45 PM
I answered your post on another forum. The dimmer and ignition switch use the same hold down fasteners. You "adjust" by moving the switch up or down with it's slotted mounting holes.
Old Feb 15, 2010 | 07:42 PM
jakesm89's Avatar
just saw your other post, thanks alot ill see if i cant get it fixed tonight
preciate it guys
Old Feb 15, 2010 | 08:20 PM
jakesm89's Avatar
k so now ive got the bolts loose and the dimmer switch will move but the ignition isnt budging??
Old Feb 15, 2010 | 09:40 PM
Keep at it or take it off and scope it out. Just make sure you don't move the switch posittion or the key when it is off. Ignition switches wear out too, so you might consider that to be your problem.
Old Feb 16, 2010 | 09:28 AM
jakesm89's Avatar
what else could be holding it on? ive got the bolts OUT and its not moving..maybe the brake cable?
Old Feb 16, 2010 | 04:27 PM
jakesm89's Avatar
problem solved, got a switch off a 92 firebird and fired right up
liamcg97
Nov 25, 2019 05:55 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
tds1213
Nov 27, 2014 12:55 PM
