Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Injector help/question
Old Jun 29, 2007 | 06:18 PM
BLDun's Avatar
I sent my fuel injectors to a place to have them sonic cleaned and flow tested and UPS has lost them!!!!!!! So, if I have to buy new ones is the only thing I need to match the 36#? - The ones I had were 36# Accell's. Will any 36#'s work?? what about resistance???
Old Jun 30, 2007 | 12:01 PM
You'll want them all to be identical, with regard to electrical resistance, fuel flow rating, open/close speed and sensitivity to system voltage (offset), etc. Other than using 8 identical brand/part # injectors, its hard to see how you could accomplish that. You should also have the replacement injector flow tested to see how close it matches the other 7.
Old Jun 30, 2007 | 02:15 PM
BLDun's Avatar
I might not have been clear enough. I sent all 8 of them off and UPS lost them somewhere in Dallas/Ft.Worth. My car is dyno tuned for 36# injectors and had the Accells on when it was tuned. I am going to have to buy 8 new ones. Will any make work as long as it is 36#??? I found some SVO's and thought I might get them but I want to make sure they will work OK.
Old Jun 30, 2007 | 02:45 PM
seawolf06's Avatar
I think you'll need a retune in order to use the Ford injectors because of a different fuel pressure rating. Go with Delphi/Siemens.
Old Jun 30, 2007 | 03:23 PM
BLDun's Avatar
I just got an email from Jeff Chreech of Carolina Auto Masters - who did the original tune - and he said all I would have to do is put the SVO's in and I would be good to go. I hope he's right!
Old Jun 30, 2007 | 07:56 PM
rskrause's Avatar
Moderator
The difference is very small. I think it will be fine without re-tuning.
Rich
Old Jun 30, 2007 | 08:15 PM
axehead's Avatar
where can a fellow buy some 30lbs. SVO's?
Old Jun 30, 2007 | 11:11 PM
Ignore my comments.... I missed the point of your post, and thought you were looking to replace only the missing injector.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
