Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ignition problem: key won't turn far enough.
Old Aug 11, 2010 | 07:34 PM
rpinson's Avatar
Today I went to my car to go to lunch and it wouldn't start. The key will turn far enough to turn the lights and radio on, but will barely turn at all further than that (not enough to crank the car). After doing some reading, I thought it was the switch but now that I have everything taken apart, I'm not so sure. Even with the switch off the column, the key won't turn any further. Is the actuator bar sticking or something? Do I need to replace the ignition cylinder itself or was I right in assuming it was the switch and a new one will fix the problem? I'm at a loss here.
BTW, I never had any symptoms at all of a bad switch like most others have reported.
HALP!
Old Aug 25, 2010 | 09:13 AM
jakesm89's Avatar
yes, its the rod. try tilting your column all the way down(pulling down on the wheel and on the tilt bar) and starting it.
DirtyDaveW
Dec 1, 2016 05:37 PM
eazyZ
Mar 1, 2015 07:12 AM
tds1213
Nov 27, 2014 12:55 PM
formula79
26
Aug 5, 2002 12:21 PM
