Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
icm check
Old 05-07-2008, 02:27 PM
roller71's Avatar
icm check
what is the best way to check you icm yourself
roller71 is offline
Old 05-13-2008, 12:36 PM
magnumv8's Avatar
I took mine to AutoZone and they tested it. I had them run the test 4 or 5 times in a row to make sure it still worked after it got hot.
magnumv8 is offline
Old 05-13-2008, 02:12 PM
feenix88's Avatar
all u need is a voltmeter because the specs are to check the resistance. Call autozone and they have a book with the specs and how to perform the test. The haynes manual also has it. The first test is for the primary, which is the two female connectors that are next to each other. I am not sure what the spec is. The second test is to put the positive terminal on the part the plug goes on, and the neg side in the female connector that is in the top left. I also dont know the spec for that either
here you go: http://shbox.com/1/coil_testing.jpg
feenix88 is offline
Old 06-01-2008, 10:35 AM
roller71's Avatar
autozone told me they couldnt check mine, the dealer said it had to b in the car, said the same about the pcm. what good is a dealer shop if you have to take the whole car for them to check a part.
roller71 is offline
Old 06-01-2008, 02:49 PM
feenix88's Avatar
dealer was wrong about the icm. Find out why autozone couldn't check it. They have a machine and a catalog that goes with it and a bunch of different connectors. They look up your car in the book, it tells them what connector to use, then they hook up the connector to your icm and to the machine. It runs about a minute long test and then decides if it is good or not. the machine is small and is usually in a drawer within a rolling cabinet. The connectors are in the drawer underneath the machine. Or call up and ask another local autozone. Or speak to the manager at the one you went to originally and see what the problem was. Maybe the machine was broken? good luck.
feenix88 is offline
teal98
15
09-16-2002 01:23 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
Quick Reply: icm check
