Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel in tank for one year...any good?
Old Sep 7, 2007 | 09:24 PM
Chevycobb's Avatar
My car has sat while doing an engine rebuild for a year with about 1/4 tank of fuel in it. I'll replace the fuel filter anyway, but is that too long for fuel to sit in the tank? I'll be starting this thing up soon and want to make sure it will be ok. If it is, should I just run it out and then fill it up, or go ahead and fill it up with new fuel while to old stuff is in it still??
Old Sep 7, 2007 | 09:51 PM
jefferino's Avatar
I did it in mine when it sat for 2 years...add as much new as possible. Also DONT do the fuel filter til after because it will get trashed anyways. I also added some lucas fuel treatment. it is not recommended to do this but oh well, either drain the whole thing or just do preventive maintenance after it is empty and filled a couple times..
Old Sep 7, 2007 | 09:52 PM
JooneJune's Avatar
I would just syphon in out and put some fresh gas in it...
Old Sep 8, 2007 | 08:17 AM
Chevycobb's Avatar
is there an easy way to drain it?? can the fuel filter be removed and just turn on fuel pump to pump it out?
Old Sep 8, 2007 | 09:03 AM
1racerdude's Avatar
Put a couple of gallons of fresh in it and burn it. I would prefer to drain it if it doesn't involve removing the tank.
Old Sep 8, 2007 | 10:26 AM
Chevycobb's Avatar
yeah I really dont want to remove it...i'll probably just buy a couple gallons of fresh 93 before firing it up
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
