Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Sending Unit
Old Aug 30, 2007 | 09:43 AM
IROCThisZ28ForLife's Avatar
Lightbulb Fuel Sending Unit
Is the Fuel sending unit for a LT1 car (Specifically a 94), the same as a LS1 car sending unit?
Old Aug 30, 2007 | 12:30 PM
Irish350's Avatar
i asked around, but no one knew... id say check with checker/kruger/advance/autozone/whatever.. have them find the part number for the 94 and then have them check it with an ls1.
Old Aug 30, 2007 | 02:25 PM
irishz28's Avatar
no the sending unit is diffrent on a ls1 car. the ls1 sending units have the fuel pressure regulators on them.
Old Aug 30, 2007 | 03:11 PM
IrocSS85's Avatar
yep, totally different. diff. hose's setup and everything on the outside.
Old Aug 31, 2007 | 05:37 AM
well that sucks...
Old Sep 1, 2007 | 06:42 PM
where can i get one for a decent price?
Old Sep 2, 2007 | 12:10 AM
IrocSS85's Avatar
why do you need the whole sending unit? why not just replace the fuel pump with a racetronix kit, or just a walbro fuel pump?
Old Sep 2, 2007 | 11:44 AM
When you ask about the "fuel sending unit", are you asking about the complete fuel pump support bracket/level sender/pump setup (not the same)? Or are you asking about the level sending unit - the rheostat with the arm and float attached to it (may be the same)?
Old Sep 2, 2007 | 12:17 PM
Fierotom's Avatar
my question: can I change this parts separate?
I ask beacuse I think my rheostat is shot.....
thanks
Old Sep 2, 2007 | 04:01 PM
Based on my experience about 6 or 7 years ago, GM did not sell the the float/level sender as a separate piece. You had to buy the complete pump support asembly (no pump) with the sender, and drill the rivets out to remove the new sender, and move it to the old support assembly (my support assembly had been modified for a Bosch pump and -AN lines). I think I may have seen a post recently where someone was able to find a replacement sender from a non-GM source.
Old Sep 3, 2007 | 12:17 PM
Fierotom's Avatar
thx for the information Injuneer....
I look for this posting later...
Old Sep 8, 2007 | 11:43 AM
well my gas gauge give me the wrong readin, i was lead to beleive it was the sending unit, i called chevy up and got a price of $516 before tax i was like STFU!!!!!!!!!!
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
