Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Sending Unit
Old Jan 9, 2011 | 09:12 PM
Airplanedoc's Avatar
Fuel Sending Unit
Does anybody other than the dealer sale a fuel sending unit I have a Racetronic pump to install but my sending unit is bad.
Old Jan 14, 2011 | 07:24 PM
byrons1502's Avatar
Re: Fuel Sending Unit
I couldn't find one.
Old Jan 14, 2011 | 09:10 PM
I found you can buy an AC Delco for about $277 beats $400 from the dealer, I bought one at a salvage yard I'm doing the install right now.
Old Jan 15, 2011 | 07:44 AM
I assume by asking about the "sending unit" that you are having a problem with the fuel level sensor. If that's the case, check around in parts stores for a level sensor only.
10 years ago when I had a problem, no one made a replacement sensor, and I had to buy a complete fuel pump support unit, as you appear to be trying to do. Even after I bought it, I had to drill the rivets out of the sensors on both support units, and swap the good sensor to the old support bracket, because the old bracket had already been altered for a Bosch pump and braided S/S fuel lines.
At this point, I think someone may be making a replacement sensor. Worth asking around, rather than paying $277 for a lot of parts you don't need.
If you actually need to replace the entire fuel pump support unit, I apologize for misunderstanding your problem.
Old Jan 15, 2011 | 08:43 AM
No one appears to make a replacement sending unit, if I buy a pump which I don't need it dose not coming with the sending unit. My sending unit dose not work but my real problem is that the rust on the complete assembly the hanger, I bought one at a salvage yard $50 and installed a racetronix pump on it last night it appears to be working. I hope to start the car this weeking I bought the car with a blown motor three years ago I have yet to drive it.
Old Jan 15, 2011 | 04:17 PM
You can check the level sensor with an ohm meter. Courtesy of Shoebox:
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Old Jan 15, 2011 | 10:27 PM
I did check it courtesy of Shoebox he has alot of good information
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
