Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel schrader valve....stem
Old Jan 22, 2007 | 11:04 AM
camzaro28's Avatar
I took the n20 off the car a couple of days ago, and lost the stem that goes in the schrader valve.
Called local GM shop and they told me $34.
Are all GM vehicles using the same setup?
What is my best option for this part?
Thanks in advance
P.S. at the moment I cant take the fuel solenoid off until I have this.
Old Jan 22, 2007 | 11:26 AM
30th6's Avatar
will a tire valve stem core work?just a thought
Old Jan 22, 2007 | 12:05 PM
camzaro28's Avatar
I was thinking the same thing, but I have no idea
Old Jan 22, 2007 | 12:40 PM
Mean Green's Avatar
don't quote me, but I believe a schrader valve is one universal standard. I believe every component is the same standard size.
however, I'd be wary of using a tire valve, because the rubber seal may be a different type and won't hold up to gasoline exposure. If you don't want to pay $34 for the valve you could just put on an -AN cap. AN-4 is the size I believe, they're like $5 for 2 at most places.
Old Jan 22, 2007 | 02:57 PM
camzaro28's Avatar
Thanks Mean Green, that is the other option I had in mind, but didnt know they sold such a thing.
Where could I buy one of these? advanced?
Old Jan 22, 2007 | 03:42 PM
mourningyou's Avatar
I had the same problem on a car that I was fixing for a friend, the schrader valve stem in their car was fried, and leaking gas everywhere. I checked with every normal auto parts store around and couldn't find anything other than a tire stem core, which I ended up using. I imagine that the real core will not have a rubber seal.
Advanced doesn't carry -AN gear.
Old Jan 22, 2007 | 03:51 PM
SevenStars's Avatar
Im using a regular tire one on mine as the old one was leaking but I do have an an cap in it incase, before I had the cap I went 1000 miles w/o it w/o leaks, idk if that helps...
Old Jan 22, 2007 | 05:28 PM
camzaro28's Avatar
Well thanks for the replies guys. I will go in search of a spare rim someone has laying around.
Then put the -4AN cap for insurance.
Old Jan 22, 2007 | 07:14 PM
69z-28's Avatar
just go to a tire shop, the valves cores are laying all over my place, theyd give you a brand new one prolly, then i would go with the -4an cap like said. you shouldnt have any problems at all. few months from now, take the cap off and see if the core is leaking or not.
Old Jan 30, 2007 | 09:36 AM
OBE1 95Z28's Avatar
Here's a -4AN cap if you can't find it locally: http://store.summitracing.com/egnsea...115+4294906750
Old Jan 30, 2007 | 10:02 AM
camzaro28's Avatar
Thanks alot OBE, I actually couldnt find it anywhere! I looked in the summit catalog at home and couldnt find it, but figured they would have it.
By any chance this wouldnt be the stem would it? I posted a thread on this part a while back when I did my fuel pump and noone knew what it was.
http://img.photobucket.com/albums/v6.../fuelvalve.jpg
Old Jan 30, 2007 | 11:38 AM
OBE1 95Z28's Avatar
That photo isn't the stem, the stem would have threads, a spring and a seal on it.
Old Jan 31, 2007 | 10:19 PM
KPZ-28's Avatar
Just curious if schrader valves are a universal standard and its cap takes -an 4 which is 1/4 inch. Why is my schrader valve cap 7/16 x 20 that goes to my fuel pressure test valve? Excuse my ignorance.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
tbyrne
Jul 2, 2002 05:37 PM
