Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump Relay
Old Apr 25, 2011 | 07:26 PM
94Z28LS1toLT1's Avatar
Fuel pump Relay
Hey guys,on March 7 last month I purchased a fuel pump relay because the relay went out on me,yesterday I drove the car for 20 minutes then stopped at a store then housefor about 4 hours.then when i left i tried starting the car it wouldnt fired up it just turned over. Since it was dark i left the car there,then today i checked the fuel pump relay it was bad the fuse had a rust color and smelled burned.the inside of the relay looked like it got wet.
Now what causes a fuel pump relay to burn out. I purchased the relay at autozone thank u everybody for any info.
Old Apr 25, 2011 | 08:05 PM
Re: Fuel pump Relay
The relay should not be getting wet. Moisture + electricity = failure.
Old Apr 25, 2011 | 10:17 PM
Re: Fuel pump Relay
idk how it would have got wet but i will keep my eye on it thank u for the tip buddy
Old May 30, 2011 | 02:06 PM
detroitlt1's Avatar
Re: Fuel pump Relay
i changed the relay for ****s cuz it had a burnt looking prong but still same symptoms. Ill have to do the tests for pump and regulator
Old Jul 17, 2011 | 02:56 PM
Wflow001's Avatar
Re: Fuel pump Relay
What did you find out? I too have a 94Z and currently have the same exact problem. Where could the water be coming from? I had to replace my floorpan when I bought it and now see I haven't fixed the problem. Also my relay is rusty and I can't get her to start either
94Z28 / conver to 2000 / stock LT1
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
