Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pump doesnt always stay running
Old Oct 11, 2011 | 08:55 PM
rocknroler69's Avatar
its a 93 z28 automatic, so far i have replaced the fuel pump and the fuel pump relay, but the pump still only runs sometimes. Has anyone else had this issue or have any ideas to what it could be, im thinking a bad wire somewhere in the harness or a bad ground somewhere. Any help is appreciated
Old Oct 12, 2011 | 06:58 AM
Re: Fuel Pump doesnt always stay running
Can you monitor the fuel pump control wire from the computer to the relay and see what it is doing?
Old Oct 12, 2011 | 01:04 PM
it either gets power or it doesnt, most of the time i notice it when i go to start the car and the pump isnt running, then other times it will, its a luck of the draw thing. if it does start it will only run for a little while then cuts off, then it wont turn back on until i let it sit for a while
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
F(ast)-body
Feb 26, 2003 09:05 AM
