Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump access door panel problem. pics
Old Dec 21, 2006 | 04:19 PM
TJsrh420's Avatar
my problem
WTF is that black line all the way to the left. i thought my fuel pump was leaking so i researched and cut a hole out and i kinda cut the top of that line. i wounder if thats where the fuel is comming out. HELP. all other lines are connected and i have no idea where it goes
Old Dec 21, 2006 | 05:13 PM
T56LS102's Avatar
Its a breather hose
Old Dec 22, 2006 | 09:48 AM
TJsrh420's Avatar
but wtf should it be connected to cause my car is filling up wit vapors and i can't take it. help
Old Dec 22, 2006 | 12:11 PM
krispy's Avatar
well now its definitely gonna fill with gas fumes because you cut a hole in the sheet metal
Old Dec 22, 2006 | 01:33 PM
BrokeMofugga's Avatar
Ive always done the fuel pump the hard way,by taking the tank out .toyota supra,pontiac bonneville,91 forumula firebird.sometimes its a pita.but sometimes it a breeze.later
Old Dec 22, 2006 | 02:16 PM
Is it possible the vent hose from the canister to the engine had been removed from the canister and pushed back up over the fuel tank?
This is a 97, and there's no "extra" line:
http://www.cardomain.com/member_page...3_108_full.jpg
But.... look at the "upper" metal line, which you didn't uncover.... could that possibly be the hose that connects there, and its fallen off?
Old Dec 22, 2006 | 05:06 PM
krispy's Avatar
I was doing this eariler on today, from left to right;
the 1st metal line connects to a quick connect
the 2nd one is connected as shown
the 3rd one connects to a quick connect
the 4th one takes a left hand turn then connects to a straight rubber pipe
that rubber hose is really weird
Old Jan 12, 2007 | 11:44 PM
Soccerbum21's Avatar
just did my fuel pump today and i didnt see anything like that extra line you got there.
and i cut my access door a little bit more towards the back seat to get access to the quick connects.
best bet would to be to get a buddy to jiggle the line while you're under the car trying to see which one is moving. and double check that all four of your hoses are connected
RiverMutant96
Jan 30, 2015 09:21 AM
Brake_L8
Jan 20, 2015 09:44 AM
ANDYZ28
Dec 29, 2014 09:13 PM
siguy
Nov 27, 2014 10:07 AM
MilkyClr69
Jul 29, 2002 10:01 AM
