Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pressure Question:
Old Jun 9, 2010 | 11:34 AM
NJ-LE's Avatar
Is this normal?
I've found my fuel pressure (factory pump and regulator) vary with temperature. The pressure differential on a cold or cool engine will be from ~44 to 48 psig. With a hot engine (175 - 185°F) and underhood it is ~37 to 40 psig.
Old Jun 9, 2010 | 12:08 PM
It's not temperature, it's engine vacuum (which can be affected by temperature, which affects engine speed and load) that controls the pressure. I don't see anything wrong with your pressure.
Old Jun 9, 2010 | 06:46 PM
NJ-LE's Avatar
The pressures were measured at cold idle with Freescan reporting MAP readings of .33 to .34 and at hot idle with MAP readings of .32 to .33. My thought was the higher regulator temperature makes for lower spring tension in the unit allowing the intake pressure to cause higher return flow to the tank. Just wondering if all factory FPRs act like this.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
