Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pressure problems
Old Oct 3, 2008 | 06:57 PM
blair's Avatar
I have a 97 z28 and the car is hard starting bad. Once it finally starts the car idles real hard because of low fuel pressure and then after about 1 min the pressure jumps back up to about 41-43 psi. I have changed out the fuel pump about 4 months ago along with a fuel pressure regulator and fuel filter. What could this be?
Old Oct 3, 2008 | 07:34 PM
Are you having a problem with the charging system? Does the dash volt gauge run in the red when the fuel pressure is low? How low does the pressure drop at idle on startup? When the pressure "jumps back up to 41-43psi", if that's with the vacuum line connected to the fuel pressure regulator, its a bit higher than I would expect. Typically you will see 36-38psi at idle with the vacuum line connected.
Have you checked the fuel pump relay?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
