Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pressure gauge in AC vent
Old Mar 24, 2010 | 03:53 PM
96LT1TX's Avatar
Ok, I have been looking through Autometer.com for the last hour trying to figure out what electronic gauge will work with a sender in my engine bay. Anyone already done this? I like your setup Injuneer and I am having fuel issues I think, so no better way to do it than put the gauge in!!
Thanks in advance.
Old Mar 24, 2010 | 04:34 PM
koolaid_kid's Avatar
Any of the 0-100 will work. You will have two issues: The sending unit is 1/8" and the fitting on the fuel rail is 1/4" (or -4AN); the AC vent hole is 2 5/8".
You'll need an adapter for the fuel rail, and if you select one of their 2 1/16" gauges you will need an adapter for the AC vent.
Some also recommend placing the sending unit away from the engine so it doesn't heat soak, which would require a fuel line.
Old Mar 25, 2010 | 07:55 PM
Kevin Blown 95 TA's Avatar
I have the 2 5/8" A-meter FP gauge in my central AC vent and it works and looks great. I also have a boost gauge and wideband gauge in the other two.
Old Mar 26, 2010 | 02:56 PM
96LT1TX's Avatar
Which wideband gauge are you using? I also want to put this in one of the others and nitrous bottle pressure in the third (I havent hooked it up yet, but soon).
Old Mar 26, 2010 | 10:20 PM
I couldn't find a wideband gauge to fit and I had one of the Innovate gauges which I put inside a Autometer 2 5/8" cup to match the others - fuel and boost/vac. It was a minor pain in the *** but it came out well and all three match pretty closely, but not perfectly. I'd post a pic but I deleted my photobucket account because they got so obnoxious with their ads.
Old Mar 27, 2010 | 12:30 AM
Mine is so old.... maybe 12 years or so.... that I think they have changed the sending unit/electronic module and part numbers. And I moved the sensor to an 1/8" bung on the fuel rails, so there's not much in the way of a parts list to provide you. Before the gauge was connected to the bung, I had an NOS -4AN 90* swivel fitting on the stock Schrader valve, a short -4AN x 1/8" NPT braided hose to a 1/8" NPT brass "tee", and the sending unit was mounted in the tee, behind the PCM.
Moving the sensor directly on the rail has not presented any problems, and its been there for 10 years.
http://www.injuneer.com/images/photo...r/DCP02679.jpg
http://www.injuneer.com/images/photo.../DCP04227a.jpg
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Moshbmx1
Feb 17, 2015 10:51 AM
Jul 4, 2005 05:00 PM
