Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel line(s) help!
Old Jul 5, 2007 | 05:15 PM
BLDun's Avatar
Fuel line(s) help!
I am changing my fuel lines to braided and when I fed the existing lines back through the wheel well the return line began leaking gas so I put the end in an old bottle I had and figured it would just drain the filter amount or something. I can't get it to quit running. I have half filled a one gallon jug and then I lifted it up in the air and tied it off until I can figure out what to do. How much gas should come out???? I can't unhook it underneath until it quits flowing.
Thanks for the help!!!!
Old Jul 5, 2007 | 05:30 PM
mdacton's Avatar
how much gas is in the tank?
it will stop unless its siphoning out.
Old Jul 5, 2007 | 05:41 PM
BLDun's Avatar
Not sure. I have the battery and everything unhooked but if I remember correctly should be about 1/2 tank. If it's siphoning any way to get it to quit without draining the tank???
Old Jul 5, 2007 | 05:49 PM
mdacton's Avatar
blow air in it.........it will only keep siphoning if it keeps the flow, disturb the flow it will stop
Old Jul 5, 2007 | 06:20 PM
BLDun's Avatar
thanks
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
