Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel line routing
Old May 25, 2008 | 07:14 PM
mdacton's Avatar
Fuel line routing
Where are your lines routed and how.
I have a -10 feed and -6 return.
I don't like how they are routed to the engine compartment and was thinking about coming through the shock tower rear with a bulkhead. But how to get in the wheelwell? Do you guys have the line just under the frame or what?
My question is should I "notch" the area and run it where the factory line went. The way my subframe bars are welded in that area I don't have the room like you do with stock lines, mine is all boxed in where the subframe bars are welded in.
Old May 27, 2008 | 09:20 PM
mdacton's Avatar
anyone?
I'm looking for ideas
Old May 30, 2008 | 01:02 PM
roguedriver's Avatar
I have mine running where the stock ones were, but i have an -8an feed and -6an return. They just fit in there with my subframes. I also ran them through the original hole in the shock tower.
Ken R.
Old Jun 3, 2008 | 07:51 PM
edholio's Avatar
If you want some ideas here is what I have done.
http://edholio.smugmug.com/gallery/1...59250553_mxPKN
-10 feed and -10 return. Any questions just ask?
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
