Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel line
Old Jan 12, 2009 | 02:08 PM
ShownomercyZ28's Avatar
Fuel line
Is a 6AN line a good size for a 383?
Old Jan 12, 2009 | 02:42 PM
ak95ta's Avatar
It's about the same as stock, should be plenty unless you are FI.
Old Jan 12, 2009 | 02:45 PM
Nope, just a 383 build.
Old Jan 12, 2009 | 02:53 PM
ak95ta's Avatar
Id stick with the stock setup and a high flow pump until you are over 600hp, then upgrade.
Old Jan 12, 2009 | 02:55 PM
Well I can get 15 ft for 35 bucks local, so I figured I could get fittings welded in the rails and get rid of the ugly stock routing....
Old Jan 12, 2009 | 05:32 PM
ak95ta's Avatar
You'll be surprised how quickly 35 bucks turns into 500 bux or even more(I have more then 1500 bux invested). As far as routing goes, don't run it in the tranny tunnel near the flywheel, as it is against NHRA rules.
Old Jan 12, 2009 | 06:02 PM
1500 in a fuel system alone???
Old Jan 12, 2009 | 06:47 PM
lethal93ta's Avatar
it dont take long thats about what I have into mine, fittings and braided line get expensive fast.
Old Jan 24, 2009 | 06:35 PM
OneShoe50's Avatar
Ohhh, pretty.... pretty expensive, but still pretty and clean.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
