Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Throttle cable connection to throttle body
Old Sep 25, 2011 | 05:27 PM
Airshowman's Avatar
Guys, I've installed a '94 LT1 in my El Camino and need a photo that shows how the throttle cable is connected to the throttle body. There seems to be two connections on the throttle body, one for the cruise control and one for the throttle cable, but I don't know which is which. If the throttle cable rides in the cam (not the ball socket), what does the end of the cable look like and what secures it in the hole? I do not have the original Z28 throttle cable, so will need to buy an aftermarket cable...but I don't see any at Jeg's or Summit that look like they have the proper connection to the throttle body.
Old Sep 25, 2011 | 10:08 PM
Re: Throttle cable connection to throttle body
Ge here and look at the ninth bullet under removing the intake manifold. It says and shows how the cables are connected.
Old Sep 26, 2011 | 10:42 AM
Airshowman's Avatar
Thanks, it looks like I will need to buy a generic cable and machine a dowel, then drill and tap for a set screw in the end of the dowel to make the connection. A little more work than I wanted, but doable now that I know what the original cable end looked like.
Parts Wanted
Mar 17, 2015 11:24 PM
CARiD
Feb 9, 2015 09:35 AM
edman
Jan 25, 2015 02:41 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
