Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
car wont start! no spark! HELP!!!!
Old Aug 11, 2011 | 10:12 AM
kamasutra8769's Avatar
ok i have been having some problems with my 94 z28 this past week, first of all the radiator hose popped off when i was going down the road and i sucked some coolant up threw my cold air intake. car running like **** and misfiring on 2,4,6,8. pulled a code yesterday for the o2 sensor, was going to replace today. anyways. Today when i went to go to work,i got in the car and started it and as soon as it started up it died, and wont start again. I pulled a wire off of one of my plugs and put a old plug in it and there is no spark to the plugs. wtf. Now i have been reading up on this for 4 hours now. Everyone is saying bad opti, bad coil, bad ICM. idk, im not good with electrical. I disconnected the battery and let it sit for about a half hour and reconnected it and tryed to start it and the battery was dead, so i charged it up but still no start. now here is a list of what i have replaced in the last couple months.
Brand New Opti
water pump
radiator
starter
mass air flow sensor
plugs + wires
coolant temp sensor
coolant temp switch
(thats about all i have done to the motor)
please help, my friend owns a LT1 shop and he is going to bring a couple coils and ICM's over later tonight, but i kinda wanna get ahead of things now. Please help. if there is anything you need to know ask and ill tell you. Thanks so much
Old Aug 11, 2011 | 05:13 PM
Re: car wont start! no spark! HELP!!!!
What was the exact numerical code? Did you recheck the codes after it refused to start?
Old Aug 12, 2011 | 07:58 PM
it was my ICM, guess it fried when i tried to start it, and the whole misfiring thing was my bank 2 upstream O2 sensor, still has a little hesitation and slight misfire from time to time, but im sure its my plugs from it running so lean i think they fowled out! ill change them sunday!
Noenav
Mar 1, 2019 07:38 AM
Noenav
Dec 6, 2014 07:35 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
