Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Breakdown at operating Temperatures
Old Apr 17, 2011 | 08:55 PM
Graven's Avatar
I have a 1997 body with a 1995 LT-1 true Z-28 engine with 66k miles on it. Had to replace the original optispark due to seal leaking and getting water in it. After about a year out of nowhere it runs horrible after it warms up. I have read other threads and most seem to point to the optispark at this point. I have replaced spark plug wires,coil, ignition mod, temperature sensor in heads and in the water pump, new spark plugs etc.
Old Apr 17, 2011 | 09:37 PM
Re: Breakdown at operating Temperatures
Have you scanned it? "Warm" means its transitioned to closed loop. May be a problem with the O2 sensors, or possibly the fuel pump overheating.
Old Apr 19, 2011 | 02:33 PM
OBE1 95Z28's Avatar
FYI the temp sensor in the head only drives the temp gauge; the temp sensor in the waterpump is what the PCM uses to determine temp for initiating closed loop.
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
