Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
backfires under load
Old Apr 29, 2010 | 07:34 PM
smoka stang's Avatar
the car will sit and ilde fine all day long once you put it under load it backfires by backfire I a loud pop out the exhaust . Its very random it might do it once in a minute or 5 times . Just about everything on the car is new . Everthing listed is new : Opti,ICM,coil,plugs,wires,fuel filter, . The fuel pressure stays around 35 may go up to 38 or 39 but falls no less than 35 psi. I was gonna change the fuel pump but not sure if its the problem . Not showing service engine light or any codes on the scanmaster. Im not sure what to do ive triple checked everthing . Someone told me could be a stuck valve and to double check the valves. Everyones imput is greatly apreciated
Old Apr 29, 2010 | 10:14 PM
Please post only on one forum. Do not cross-post.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
form94
Sep 23, 2015 07:30 AM
tommalcolm
Sep 11, 2015 03:39 PM
