Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Air/Fuel Ratio Gauge install ?
Old Feb 5, 2011 | 12:28 PM
450hplt1's Avatar
This may be a dumb question but when installing this gauge there is no where for the factory wiring to go. Doesnt the pcm need this? Do I have to splice some wires together? I tried to search first on here but couldnt find anything. Thanks for the help!
Old Feb 5, 2011 | 03:41 PM
Va-Z's Avatar
Re: Air/Fuel Ratio Gauge install ?
Depending on the gauge, a majority of them pick up the feed from the o2 sensor. No need to tap into the PCM directly. The other wires that you should have will be your power, ground and maybe a dimmer.
Old Feb 5, 2011 | 07:14 PM
Are you installing an A/F ratio gauge that uses the stock, narrow-band sensor, or a gauge that uses a wide-band sensor? The wide-band requires that you add a second bung, or install it where the stock sensor is located and use the 0-1V emulation mode output from the wide-band controller to feed the PCM.
Old Feb 6, 2011 | 04:36 AM
MikeGyver's Avatar
Nobody can help you without the pertinent basic info.
Old Feb 6, 2011 | 01:29 PM
450hplt1's Avatar
It is a wide-band. I think I'm just going to weld a new bung in. It seems like the easiest to me. Will it read accurate if I weld it at the end of the y pipe or is that too far down? Thanks.
Old Feb 6, 2011 | 03:01 PM
The wide-band controllers have extensive temperature correction built in. Should not be a problem. Other issue will be that you are only looking at one bank of the engine. Might want to consider a dual sensor unit.
Old Feb 6, 2011 | 04:55 PM
450hplt1's Avatar
What if I put it in the pipe where the two sides meet? Would that work?
Old Feb 6, 2011 | 11:32 PM
Let's say one bank is running rich, and one bank is running lean. The combined exhaust will showup as neither. As a minimum, have an extra bung welded to each side of the exhaust, with the sensor in one and a plug in the other, so you can swap the sensor to either side.
Or:
http://www.altronicsinc.com/pages/o2alert.html
http://www.rpmoutlet.com/mt.htm
Old Feb 7, 2011 | 12:01 AM
MikeGyver's Avatar
My wideband is 1 foot from my exhaust tip.
Old Feb 7, 2011 | 12:56 PM
450hplt1's Avatar
Does this mean it reads off both sides?
Old Feb 12, 2011 | 05:05 PM
450hplt1's Avatar
Ok guys I got this gauge installed and need help again. I put it in the end of the y pipe like i said just to see what it would read and it is too high to read at idle and around 13.0 from 4000 rpms and up.
Do you think this is right or not because I have it reading off both sides?
It was throwing lean codes before I fixed the fuel pressure but now no codes and 44psi idle and 50 WOT. Let me know what you all think. Thanks.
Old Feb 12, 2011 | 09:47 PM
Your fuel pressure sounds high. Usually you will see 43.5psi at idle, with the vacuum compensation line off, and the pressure will drop when you reattach the vacuum line, proportional to intake manifold vacuum. With a cam more aggressive than stock, you might only see a 4 or 5psi drop. When you go WOT the pressure should return within 1 or 2psi of the "no vacuum" reading.
What does the A/F ratio read at idle? Should be 14.7:1. When you indicate you see 13:1 at 4,000 RPM and up, is that at part throttle, or close to WOT throttle? For max torque/HP in power enrichment mode (PE mode = 70% TPP or greater, depending on the tune), its not unusual to see the sweet spot in the range of 12.8 - 13.2:1.
Old Feb 13, 2011 | 12:54 AM
1badasZ's Avatar
not to hijack but do most leave them hooked up all the time or take em back out and put the plug in?
Old Feb 13, 2011 | 01:31 AM
MikeGyver's Avatar
Run it all the time.
Old Feb 13, 2011 | 01:36 AM
MikeGyver's Avatar
Your smog pump was probably on...
You need to let the car run for 5 minutes so it enters closed loop. It should try to hold 14.7-15.2 Open loop will likely read 13.x
You cannot have any intake leaks, or exhaust leaks upstream of your o2 sensors or the wideband.
huh? 1 sensor reading all 8 cylinders is the default setup.
Un-ghettorig/fix your fuel pressure for starters (unless the PCM has been tuned to reflect this change).
