No pictures but the sheet metal behind the rear seat (under the car above the differential) is the mounting location for in-line fuel pumps; should work well for a filter.
I located my Aero-motive filter in the engine motor compartment infront of the driver's side inner fender access opening (97 Camaro). Easy in/ out access. Used a piece of 2" PVC cut in half and glued a similar fender mount with ty-raps (2) to secure. I should take a pic.
I ran dual Walbro 255 pumps (modified tank bulkhead plate) with (2) -6an lines (socketless hose) to a moroso Y block, and, a single -8an line (Alum hard pipe & braided flex) to the motor compartment and the Aeromotive filter. The Y block is where the stock filter was. Did some bracket engineering and it fit nicely in that spot. I hope you got the pic. I don't have high speed. Sorry, state is going to tax the i_net.
