Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
96 Z28 fuel problems
Old Jan 17, 2007 | 03:13 PM
brucetrentcamaro212's Avatar
I have a 96 lt1 with 80,000 miles on it. I"ve put new bosch +2 plugs and msd 8.5 mm wires on it new rotor and cap, and new distributor. I have also put a new coil on too. The car has a hesitation at lower rpms and not so much at higher rpms. The car does need a valve adjustment. would that be the problem? I also have a vacuum line off and I dont know where it goes. It is on the rubber intake bellow. Its has a blue plastic piece on it. I have no Idea where it goes from there. help please!!!
Old Jan 17, 2007 | 03:21 PM
mdacton's Avatar
the hose with the blue thing is a vent line that goes to the dist.
That may cause a problem if you have any vac. leakes behind the mass air
Valve adjustment could also cause some problems. Fix that line tho it goes on the 4-5 o'clock driver side of dist. there are 2
Old Jan 17, 2007 | 06:47 PM
Thanks I will get that vac put on. Is it hard to do a valve adjustment yourself. Any tips I should know before trying it.
Old Jan 17, 2007 | 07:25 PM
84firebird's Avatar
valve adj is easy, just idle the motor, warm it up, pop the valve covers, and loosen each rocker til it clicks, then tighten til it stops and go 1/4 turn more, and do each one
Garcia5
Jul 7, 2022 06:51 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
