Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 camaro wont start
Old Mar 8, 2011 | 03:01 PM
luvmyroro's Avatar
Unhappy 95 camaro wont start
my car stopped slowly while i was driving on the freeway it was as if all the power was slowly going away. i got a jump still nothing. checked my battery and fuel everything is good. my security light is not on anymore but it was always on never flashed. i waited two days my car started for aprox. 10-15 seconds and then cut off. alot of people are telling me its my kill switch. what is that and where is it located?? also when i put the key in the ignition and try to start it nothing happens at all(soundless) my fan just comes on.help please
Old Mar 8, 2011 | 11:10 PM
Re: 95 camaro wont start
There is no "kill switch" unless a previous owner added something as a security device.
Have you checked the fuel pressure? That will tell you if you have a faulty fuel pump.
It may also be a faulty ignition switch. See if this helps (courtesy of Shoebox):
http://shbox.com/1/pass_key.html
Old Mar 9, 2011 | 02:01 AM
luvmyroro's Avatar
i would have to check the fuel pressure. the previous owner had a alarm system on my car. a friend touched some wires together in my car and an alarm came on i had no idea it was even there. i am no mechanic and every wire pretty much looks the same to me. this has happened to my car before i waited two weeks and it started, could my starter possibly be out???
Old Mar 9, 2011 | 05:21 AM
A weak battery, loose connections and corroded terminals can all cause the starter not to get power. But you lost power while driving. You may have mutiple problems.
Old Mar 9, 2011 | 10:46 AM
luvmyroro's Avatar
thanks for your help i really appreciate it. i will check all those things. what could possibly be the worst case scenario???
Old Mar 9, 2011 | 06:58 PM
luvmyroro's Avatar
got a new battery. car still doesnt start. i really dont know what the deal is with my car anymore. i need major help please
ChrisFrez
Dec 7, 2014 06:01 PM
globalprojeff
Dec 6, 2014 04:18 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 23, 2014 10:33 AM
Jul 4, 2005 05:00 PM
