Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
94 Z28 Won't start
Old Oct 25, 2010 | 12:20 PM
zdreamin's Avatar
94 Z28 Won't start
It's turning over just won't fire- fuel pressure was in spec at the rails (don't remember exactly what the pressure was, on the low side of spec), coil/icm is fine (a buddy took mine and put it on his car and it's working).
I'm thinking opti but I've been told that they usually don't just die.
Any input would be appreciated.
Old Oct 25, 2010 | 05:00 PM
Have you scanned it for codes? There are codes that don't turn on the SES light. The worst one is DTC 16 for loss of low resolution pulse signal from the optical cam position sensor in the Optispark. When that one sets, the PCM shuts down the fuel system.
Have you verified that you have spark?
Old Oct 25, 2010 | 05:42 PM
zdreamin's Avatar
No spark which is why I pulled the coil/icm and had my friend try it on his car.
I haven't pulled the codes from it, I thought I could do it without a scanner but haven't been able to figure it out. LOL
Old Oct 26, 2010 | 07:33 AM
You need an OBD-I scanner to pull codes on a 94.
Old Oct 26, 2010 | 02:38 PM
zdreamin's Avatar
Thanks, I'll see what I can come up with.
Britbilly
Jan 7, 2015 08:49 PM
Jessie4tin
Jan 7, 2015 08:53 AM
nophix
Nov 30, 2014 10:26 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Brent94Z
Mar 21, 2002 04:44 PM
